Speculation Maybe Harmony 83" in 2022
This post has 8 Replies | 0 Followers
Emil Jensen
Denmark
Posts 766
Emil Jensen Posted: Wed, Nov 24 2021 6:32 AM
LInk
LG G2 will come in 83"
And C1 will come in 42" but I do not think they can get that to work in a Contour, as the Stage is to wide.
seethroughyou
UK
Posts 999
83 inches on a TV. The world needs 83 inch panels as much as the Pope needs condoms. 83 inches…..??!!
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Nov 26 2021 12:12 PM
Need and want are very different.
I would say they should make it happen as they could easily do it and sell it at half the price of the 88”. Ihmo it’s a better idea than the 88” now.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
vlohjr1
Posts 553
vlohjr1 replied on Fri, Nov 26 2021 1:10 PM
Mikipidia:
I would say they should make it happen as they could easily do it and sell it at half the price of the 88”. Ihmo it’s a better idea than the 88” now. New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0
mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Would the 83 support 1st gen harmony apart from the grill?
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Nov 26 2021 1:24 PM
In terms on bolt pattern and app etc yes. Iirc the main difference was for the weight of the 88” with all the covers on the back. So since we don’t know the weight of the 83” or of the wing covers its hard to say. The mechanism is the same for the wings but it has 3 different springs in it, those can be switched over though. If it’s other parts like the legs that push up, then I don’t know fully yet.
laseralex
Posts 240
laseralex replied on Sun, Nov 28 2021 4:46 AM
seethroughyou:
Big Smile Big Smile Big Smile
That said, I have been using a projector on a 120" screen for the last decade or so, and anything much smaller just seems annoyingly small.  The cinematic experience really is very nice.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
kawo
Posts 148
kawo replied on Sun, Nov 28 2021 10:45 PM
coming from a 65" Harmony I upgraded to the 77". I already placed everything to be ready to move to 88"... but the 88" is just insane in price.
The 83" however is priced currently as my 77" last year and does not have the heavy external power supply, so I would love to upgrade!
vlohjr1
Posts 553
vlohjr1 replied on Mon, Nov 29 2021 11:16 AM
Mikipidia:
In terms on bolt pattern and app etc yes. Iirc the main difference was for the weight of the 88” with all the covers on the back. So since we don’t know the weight of the 83” or of the wing covers its hard to say. The mechanism is the same for the wings but it has 3 different springs in it, those can be switched over though. If it’s other parts like the legs that push up, then I don’t know fully yet. New: Beovision Harmony, Beolab 50's, Beolab 28's, Beolab 18's, Beolab 17's, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay Portal, Beoplay H4 gen 2, Beoplay E8 3.0
does anyone know the spec difference between MKI vs MK2 harmony please? Thanks
Curly
FL, USA
Posts 366
Curly replied on Mon, Nov 29 2021 11:19 AM
+1
I didn't even know there was a mk2 Harmony. What's changed?
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Page 1 of 1 (9 items) | RSS
