Hello!
I would like to know, if there is a small fuse in the power supply on this model?
Mine has suddenly gone total dead 🙁
Poul
What's the Google Home mod?
matteventu:What's the Google Home mod?
I managed to dismantle the Beolit 12, and there is a 3,15 A fuse in the 230 Vac powersupply.
The Fuse was off, so thats why the Beolit 12 was totally dead.
Further mesurements neaded to find out why.
No fault inside the Beolit 12.
I think the brokken fuse is caused to a bad battery-pack.
Anyway now it works again with a new fuse and battery-pack, but it is a rather complicated model to dismantle.
PoulBerg:No fault inside the Beolit 12. I think the brokken fuse is caused to a bad battery-pack. Anyway now it works again with a new fuse and battery-pack, but it is a rather complicated model to dismantle. Poul
