Adding subwoofer to Beosound 4000
This post has 4 Replies | 2 Followers
beobeo234
Posts 1
beobeo234 Posted: Sun, Nov 28 2021 7:39 AM
Hello, I have a Beosound 4000 with two Beolab 6000 speakers. I wanted to add a subwoofer to my setup and was considering a Beolab 2. I believe my Beosound only has two output ports so I think I’d have to connect the speakers through the Beolab 2 and then connect the Beolab 2 to the Beosound. I was wondering if this is correct or whether there is a better way (that would retain Left/Right) speakers. Is there any additional adapter that would help? Thanks!
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Welcome to Beoworld!  Yes, you can add either a Beolab 2, or any other brand of active (powered) subwoofer if you prefer.  For the best results with Beolab 2, please connect the subwoofer to the Beosound and then link the two Beolab 6000 speakers to the output sockets of the subwoofer so that the subwoofer can manage the bass across all three speakers.
Please click on my sponsor link at the foot of this page if you need any help with cables or connections and I can be happy to assist!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Millemissen
Flensborg, Denmark
Posts 14,680
The right/left setting is managed in the BL6000.
There is absolutely no problem in connecting the subwoofer to the BS4000 and then the 6000 to the BL2.
See also page 6 here:
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SPEAKERS/BEOLAB_2/beolab2_userguide_english.pdf
Millemissen
Flensborg, Denmark
Posts 14,680
Good morning Steve - you beat me on this Smile
Posts 2,165
Good morning MM,
Thanks for replying, usually you are faster than me! Big Smile
Steve.
Page 1 of 1 (5 items) | RSS
