I'm looking for the beolink accessories catalogue, I can see the one for masterlink
I'm looking the one that shows different type of or sensors including the ones with rj45 connections as well as the leads for the beosystem 4, does anyone have a link for that
Hello Kai, is the info on page 121 of the BeoLink handbook the info that you need?
Hi Johan, yes that's what I'm looking for, I already have the sensor for the beosystem 3 I'm just wondering if I can just replace the cable, I have another post about the beosystem 4, and cinema control is that something you have any experience off
