Beolink Converter NL/ML software download
This post has 14 Replies | 1 Follower
j_lowry
Posts 18
j_lowry Posted: Tue, Nov 30 2021 6:12 AM
I recently purchased a BLC NL/ML that I'm trying to setup but I've run into an issue
The software update will not download- I keep trying different connections to the internet but still it won't download. It is stuck on 1.3.0.0 but the later rev is available that might solve other issues. I connected the internet either with my home router or using my phone as a hotspot in case the router settings were preventing the download but no luck. Is there some setting I'm missing or is there another way to upload the software?
lawrencejmcook
Posts 742
j_lowry:
One of my BLC NL/ML is also stuck on software version 1.3.0.0. I contacted B&O support. They tried and failed to push an update to it, and advised me to contact a local dealer.
The U.K. dealer I contacted advised that this work has been contacted out to a third party. I could either contact the third party direct and arrange the update, or leave the device with the dealer and they would handle. In both cases I would pay the third party direct.
I don’t know if the situation is the same in other countries.
If you find an alternative method to update the software, please would you share it.
V.Lips
Colorado
Posts 1
V.Lips replied on Tue, Nov 30 2021 9:33 AM
Same problem here in the US. I have a converter on 1.3.0.0 that needs to be updated. Did the UK dealer give you a name or phone # of the third party?
Desperately need this updated.
BeoJosh
Posts 89
BeoJosh replied on Tue, Nov 30 2021 4:19 PM
I'm in the same boat, with a second BLC I just got on eBay that's not on the latest software. Haven't asked my dealer about it yet, so would love to know if there's a place I can send it to directly here in the US.
Beovision Harmony 77, Beovision Harmony 65 x2, Beovision Contour 48, LG GX 65/Beosound Stage/STB Stand
Beolab 50s, Beolab 28s, Beolab 18s x3, Beolab 19, Beoplay A9, Beosound Edge, Beosound 2 x2, Beosound 1 x2, Beosound Level x2, Beosound Core x2, Beoplay M3, Beosound 9000, Beogram TX2, Beogram 6500 White Edition, 4000c (on order), Beoremote One x8, Beoremote Halo x3, BLC NL/ML
Beoplay H95 x3, Beoplay EQ x2, Beoplay E8, Beoplay E8 Sport, Beosound A1 x2
expoman
Posts 182
Silver Member
expoman replied on Wed, Dec 1 2021 6:06 PM
Is the software update available thru the B&O service tool Mark II?
Jack
Poland
Posts 30
Yes , 50 Mb.
beojeff
USA
Posts 2,012
beojeff replied on Thu, Dec 2 2021 12:25 PM
So is the service tool how an NL/ML Converter is converted into a BLGW and vise-versa?
Jack
Poland
Posts 30
Jack replied on Thu, Dec 2 2021 1:41 PM
https://archivedforum2.beoworld.org/forums/p/30789/349392.aspx#349392
j_lowry
Posts 18
j_lowry replied on Fri, Dec 31 2021 9:21 PM
I contacted B&O support and they stated the BLC would have to be reflashed at a repair center to update the software from 1.3.0:
The reason the software update will not download is that the internal clock in the BLC cannot be changed to the local date/time and the mismatch prevents the server from downloading the update. The 1.3.0 version doesn't have a way to update the clock. Later versions of the software do have the ability to change the clock settings. Seems like an odd issue but that was how it was explained to me. If anyone knows a way around this I'd really like to know.
With the 1.3.0 software I could get everything on the ML side to work as it should by connecting a IR receiver to the BLC. But in the conversion to NL the ML sources would only show up as available when configuring the NL product-but they didn't become selectable sources when trying to play them.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Jan 1 2022 5:09 AM
One can download a later version of the BLC, but not the latest version, on the internet.
But I do not know if possible and how to install this version. I would try the USB way though.
mlgw.bang-olufsen.dk - /source/documents/Latest BLC SW/Test/
edit: Be Beware, it could also be BLGW software
j_lowry:
Did you try to fool the system by changing the date manually in the Webpage source of the BLC?
lawrencejmcook
Posts 742
Hi Carolpa, thanks for the link.
(1) The enclosing folder for that zip file suggests that it is software for the BLGW rather than the BLC NL/ML.  Will this not (irreversibly?) convert it to a BLGW?
(2) Please could you describe the process for changing the local date/time in "the Webpage source".  There is no option for setting date/time in the web interface of software 1.3.0.0.
Lawrence
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Jan 1 2022 10:31 AM
lawrencejmcook:
your right.
I viewed and interpreted the title as BLC software. But it, looking at the file name, also could be BLGW.
Jack
Poland
Posts 30
Jack replied on Sat, Jan 1 2022 11:42 AM
http://mlgw.bang-olufsen.dk/source/documents/Latest%20BLC%20SW/Test/
This is 100% BeoLink Gateway, I uploaded it.
ethuijs
Posts 68
ethuijs replied on Sat, Jan 1 2022 1:12 PM
I also recently purchased 2 NL/ML converters. I still have to instal them and configure them. Will they automaticly update when conectted to the internet? And will I get stuck in rhe update loop and make them unusable?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Jan 1 2022 2:45 PM
ethuijs:
Version 1.4.3.19864 is the latest update. Thereafter no updates anymore.
So if your BLC's have this sw version then you'll be fine.
If not you can have them updated by someone who has access to a full functional Service Tool.
Page 1 of 1 (15 items) | RSS
DigiCert Secured Site Seal
