Is it possible to build a module to add on to a BEOLINK Passive amplifier to make it a network link zone? I was wondering if there is a part from a Beosound 35 that could be modified?
expoman:Is it possible to build a module to add on to a BEOLINK Passive amplifier to make it a network link zone? I was wondering if there is a part from a Beosound 35 that could be modified?
Carolpa:Beosound Essence mkII BeoLink NL/ML converter
Hello expoman,
I am using both nl/ml converter and beosound essence mkii in a setup to drive two pairs of beovox cx100. The setup is super easy and it works like a charm! Only down side is that you need quite some space to put all this stuff and cables. Especially with the nl/ml converter which is much bigger than the essence and much much bigger than the core (as carolpa suggested) and it has no bluetooth connection to a remote (in case you don't want to control it only from your phone/tablet).
So a Core with power link out would activate the passive amp and give you volume control with a Bluetooth remote. This would be the simplest solution right?
expoman:So a Core with power link out would activate the passive amp and give you volume control with a Bluetooth remote. This would be the simplest solution right?
expoman:control with a Bluetooth remote.
