I have a BeoLink Passive 1658 Kit and i can not figuere out where i can get a t1 transformer. Are there any alternative parts for this? The 4 legs on one side are broken off and I can not get the wire of the winding soldered back on. Does anyone have an idea! It probably broke during improper transport of the shipping provider. Thank you very much!
I just skimmed the service manual - which is not as verbose as I'd like - but I guess T1 is a standard 110/220V to 24Vac transformer with probably 5-7VA..
Desolder the trafo and post a picture of the the underside, particularly the spot where the pins broke off.I'd guess that a Dremel will be the tool of choice for fixing this problem.
