Beosound 9000 mk2 problem. Advice or service needed
Yael Demedetskaya
United States
Posts 20
Yael Demedetskaya Posted: Sun, Dec 5 2021 12:39 AM
Hello everyone
I have a problem with cd and beosound 9000. Look at the video please
https://youtu.be/rlIbsw4-BhE
When I am trying to play cd it just restarts. And if before the try it was in standalone mode then after that restart it is again "tv opperated". Advuce needed. I am slightly familiar with electronics repair and can try to fix under a guidance or with advice or I need the service recommended in the New York state or neighborhood states. Thank you in advance
Beolab 1, Beolab 8000, Beolab 6000, Beolab 4000
Beosound 9000, Beosound 3000
Beoplay H95
Beogram 8002
Peter
Siemianowice Sl., Poland
Posts 111
Peter replied on Mon, Dec 6 2021 2:26 PM
you should run testmodes 71 and 73 and see what informations you will get.
Generally laser lens may be dirty however it's strange because  there should be a "pause" message before switching off.
To clean laser lens please run testmode 65 then open the cover lid, take out the mains plug and take off the silver circle, silver cover and transparent semi circle. You will have the acces to the lens which may be cleaned with alcohol and wiped gently. To be sure please also wash at least one disk with detergent or liquid soap. Then, after assembly please run testmode 73 again.
Yael Demedetskaya
United States
Posts 20
Thank you for your reply. I am sorry for the delay. I have tried to run those but it writes wrong sec. I made a video on that
https://youtube.com/shorts/cx7vLqzfcG0?feature=share
Thank you very much for help
Beoplay H95
Beogram 8002
Peter
Posts 111
Peter replied on Mon, Dec 20 2021 10:21 AM
Hi again,
this is a common mistake, when you enter to a test mode SHIFT 90258 you have then to chose the disk pushing a buton next to that disk and after that enter the mode numer 71 or 73 or any other. Please keep in mind that for test mode 71 the first disk position should be empty.
Yael Demedetskaya
United States
Posts 20
 I am sorry for the late reply.  I just had time to try everything you advised. And Now I want to emphasize my HUGE appreciation for help! It is work fine now and i am pretty happy! Thank you million times!
Beoplay H95
Beogram 8002
Page 1 of 1 (5 items) | RSS
