I see many of you have LG TVs, so maybe it's a good place to ask. I have 2021 LG model (G1) with Beosound Stage. All worked perfectly until 03.20.80 update for LG TV. First volume control was lost , after few days I realized that auto power on/off stopped working, so whole CEC broke down. Now, after few more days I have no sound at all. Tried to reset TV to factory defaults, Stage as well, reconnected cables.. still nothing. Any of you experience same issues recently?
thanks!
Did you try to replace the HDMI and network cable? If it’s really linked to an update it’s not the source of the problem, but maybe it’s not linked to the update…
diisign.com
smg: I see many of you have LG TVs, so maybe it's a good place to ask. I have 2021 LG model (G1) with Beosound Stage. All worked perfectly until 03.20.80 update for LG TV. First volume control was lost , after few days I realized that auto power on/off stopped working, so whole CEC broke down. Now, after few more days I have no sound at all. Tried to reset TV to factory defaults, Stage as well, reconnected cables.. still nothing. Any of you experience same issues recently?
I have the same setup and no issues at all, no. I reckon, sadly, the software upgrade has either failed or part-failed.
indeed, after replacing HDMI cable all is good now. Hope this one will not die in 3 weeks or so ;)
