Maybe this can help:
https://support.bang-olufsen.com/hc/en-us/articles/360041130412-How-do-I-set-up-Beosound-Stage-without-a-Google-account-
I think Apple insists to send audio over Airplay, not Bluetooth.
Also, you'll have better performance if you have the AppleTV do the streaming and send audio from the AppleTV to the Stage. This is the setup I've been using since I got my first Beosound Essence II about 5 years ago.
When I try screen sharing from my phone to the AppleTV it does work, but is not nearly as reliable.
So basically set the AppleTV to output to the Stage over Airplay, then use the AppleTV interface to choose your video stream and let the AppleTV do all the work.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
