Quick question: Essence Remote + BeoLab 28?
This post has 6 Replies | 0 Followers
Curly
FL, USA
Posts 366
Curly Posted: Thu, Dec 9 2021 1:48 PM
All, just a quick question: Does the Essence Remote pair with the BL28? B&O no longer lists product compatibility on the old Essence Remote page since it's not a current product as far as I can tell.
Thanks!
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Razlaw
Posts 4,345
Razlaw replied on Thu, Dec 9 2021 4:38 PM
I will try to remember to ask today when my 28s are installed, and/or try pairing one of my Essence remotes later. It is sitting in a drawer unused so would be great if it did.
Mikipidia
Posts 2,169
I think it will, but also haven’t tried it. May not be 100% functional because some of the commands have changed, it can’t for instance shut off my harmony. Everything else pretty much works.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Razlaw
Posts 4,345
Razlaw replied on Thu, Dec 9 2021 10:04 PM
The answer is…..yes. Asked my installer and paired my Essence remote.
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 10 2021 1:24 PM
Thanks for posting that page!
Curly
FL, USA
Posts 366
Curly replied on Fri, Dec 10 2021 2:29 PM
Huge thanks, Christian! Perfect! Thank you!
Page 1 of 1 (7 items) | RSS
