Beoplay M3, Denon x4700h, airplay latency
This post has 2 Replies | 2 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Sun, Dec 12 2021 4:52 AM
My setup is a bunch of M3’s around the apartment and a Denon x4700h in the living room.
If I Airplay to all units, the M3’s are a little bit behind the Denon. I have tried to find a latency setting on the denon, but no luck.
Does anyone have any thoughts on how to fix this?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Dec 12 2021 6:21 AM
Did you try changing the M3 Airplay Multiroom Latency setting (it can be set to relative increased but also decreased values).
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Dec 12 2021 11:11 AM
If you don't use B&O Multiroom for Airplay, I would disable this feature on all your M3s.
Page 1 of 1 (3 items) | RSS
