Beomaster 901 TR1 in FM : MPF120
This post has 6 Replies | 0 Followers
aragorn83
Posts 15
aragorn83 Posted: Sat, Dec 18 2021 2:48 PM
Hi all,
initialy I have problem similar of this topic : https://archivedforum2.beoworld.org/forums/t/35755.aspx
I change caps and some resistance and it's works BUT FM is not normal...
As i have 2 Beomaster i can identify the guilty :)
In FM section, the Dual Gate MOFSET TR1 ( MPF120) doesn't work, i switch with the other beomaster 901 (who works fine)
So i need to change it but it seem not very common... in fact in my second beomaster it a RCA 605 40822 but same thing... i can't really find it.
Someone know with which parts i can change it ?
Thanks a lot :)
(soorry for my english, i'm french ! )
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Dec 18 2021 3:08 PM
RCA 40822 can be found on Ebay
https://www.ebay.de/itm/203085023724
(I don't know and have never dealt with this seller).
MPF120 can also be found:
https://www.ebay.de/itm/174312361573
aragorn83
Posts 15
aragorn83 replied on Sat, Dec 18 2021 3:12 PM
Thanks ,
For 40822  15€ for 2
For MPF120 22€ for 1
i think it's too expensive.
there is no equivalent transistor more common i can use ?
Dillen
Posts 13,191
Dillen replied on Sat, Dec 18 2021 4:15 PM
You can buy the correct parts.
That's a good price, I think.
But of course, it's for you to decide.
Actually, I was surprised to find them on Ebay, so if you don't buy them, I could feel tempted, just to have them in the drawer.
Modern mosfets usually have a much higher gain, requiring a bit of circuit redesign, and it's rare to see dual-gates used today anyways.
But go ahead if you prefer, - take your time and look around for something with similar specs to the originals.
Do let us know if you find something.
aragorn83
Posts 15
aragorn83 replied on Sat, Dec 18 2021 5:06 PM
Thanks a lot for your response and good advice, as always ! :)
I found this : https://picclick.fr/3-x-RCA-3N204-273077271460.html
description : "RCA 3N204 Dual Gate MOSFET 40673 40822 3N201 remplacement Transistor" i don't know if it will help me or not.
Dillen
Posts 13,191
Dillen replied on Sat, Dec 18 2021 5:58 PM
Here on Ebay:
https://www.ebay.de/itm/402290096014
Not exactly cheaper...
I never tried that type, so I cannot say if it'll work. But you could try.
aragorn83
Posts 15
aragorn83 replied on Tue, Jan 4 2022 10:31 PM
hi,
so i decide to buy 2 3N204 on aliexpress for 8,30€ include 4€ of 15 days delivery.
Now the FM works normaly; i listen radio for 2hours in stereo and a perfect sound for any station.
i'm happy :)
For the moment, I confirm that it works to spare with a 3N204
Thanks and see you soon certainly for help with my other repair project :)
Page 1 of 1 (7 items) | RSS
