linking my active penta speakers with a turntable
juandange@sky.com
Posts 2
juandange@sky.com Posted: Sat, Dec 25 2021 1:12 AM
Hi guys.
a little advice if possible.
I have a pair of active beolab Penta speakers which i have previously run from a beocenter 9000 (both circa 1989).
My question may be somewhat naive - but i am wondering if i can purchase a turntable that i can plug directly into my speakers (as they have their own amps). i no longer use the beocenter 9000.
If so can anybody advise on a compatible turntable this would be a major help before i try to buy one. My current speaker leads have 4 pins, one flat and three "needle" shaped.
Stoobietoo
Exeter, Devon, UK
Posts 692
I can only see this working if the turntable has some way to control the volume it outputs.
Stoobie
PeteV
Posts 22
PeteV replied on Fri, Dec 31 2021 12:37 PM
Stoobie is quite correct, the Penta only has power amplifiers, so you would need a preamplifier, unless you can find a turntable with built-in preamp with volume control. Also the displays in the Penta's would not work.
Pete
Page 1 of 1 (3 items) | RSS
