Shape/Core errors not switching Stereo to Band on the wall
This post has 7 Replies | 0 Followers
swestland
Netherlands
Posts 73
swestland Posted: Mon, Dec 27 2021 10:51 AM
Just got my shape installed last week but it has problems with switching the sound mode from stereo to Band on the wall. I rebooted the devices but still giving errors, when I check logs I see the following error:
Status ready
USB connected
A2B
error
27. 12. 2021 09:26:06 * Soundwall: Enter error state, CommunicationError
25. 12. 2021 08:49:06 * Soundwall: Enter error state, CommunicationError
24. 12. 2021 20:49:49 * Soundwall: Enter error state, CommunicationError
Also when starting to play thought spotify connect from standby it plays the song for 2 seconds and pauses the song. When pressing play again it starts playing without any problems. But it's rather strange behavior to start in my opinion.
- Beovision Eclipse 55 Mk2 - Beolab 19 - Beosound Shape - Oppo UDP-203
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Dec 27 2021 12:01 PM
swestland:
Status ready
USB connected
A2B
error
a. On what software version does the Core run. The latest Soundwall error my Shape had was in June 2021.
b. you do have two amplifiers? If so, while starting has one a white light the other a purple one?  There seams to be an error between the two.
swestland
Netherlands
Posts 73
swestland replied on Mon, Dec 27 2021 12:35 PM
Core is running latest (I guess) software : 1.12.47460.41986660
I have only 1 amp with 4 speakers, which is running in master mode.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Dec 27 2021 12:49 PM
swestland:
same sw version. I thought you have 2 amps because of the A2B error
Is the correct design-id loaded in the Shape? See "Shape info" in the setup part of the B&o app.
swestland
Netherlands
Posts 73
swestland replied on Mon, Dec 27 2021 1:26 PM
Yes the correct design-id is loaded. I just unplugged the amp from power, waited about 60 seconds and plugged it back on. After doing this I could change the mode again from Stereo to BOW and vice versa. So maybe that did the trick?
A2B is also shown as 'ready' now.
There is no other way of rebooting the amp through the app or web-tool right?
swestland
Netherlands
Posts 73
swestland replied on Mon, Dec 27 2021 3:34 PM
But now after a few hours in standby mode, A2B giving an error. Not sure if thats a problem. Will check if I'm able to change the sound modes now.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Dec 27 2021 4:31 PM
swestland:
only the amp or the Shape?
you can reboot the Shape with the app!
swestland
Netherlands
Posts 73
I made a short video showing what the problem is.
https://youtu.be/XwZqoUVbjZ8
Page 1 of 1 (8 items) | RSS
