Beolab 5 upper bass problem
Lenny78
Posts 3
Lenny78 Posted: Mon, Dec 27 2021 2:06 PM
Hello, i am new on Beoworld. I hope i ask my question in the right forum. I got a pair of Beolab 5's, but the upper bass makes a scratching sound, when i play loud music. It gets worse if the speaker plays loud, long time. The speaker has not shot down at any point, witch koncerns me. I am afraid that its the amplifier, causing it, and not the upper bass unit.
Today i took the the unit out, and there was a little scratching noise, when i pressed it down, but not when i pushed down right in the middle. Any suggestions, what it could be?
I have actually had quite bad luck, with the upper bass in my Beolab 5's. Like my movies very loud. Change them 3 times, two times on this speaker, 1 time on the other. Every time the speaker just shuts down, and then played on, without the faulty unit. They are from 2015.
Mr 10Percent
So West, Its Now East
Posts 591
Best think is to get the unit serviced.
As per a recent post, there may be other things going on. I have seen a upper tweeter go frail on me. It may be the driver that has failed? Hard to say.
I tend to think if there is no sound anywhere or a red light - its the Eprom or chassis electronics. if everything else is working, it may be driver specific.
Have you tried playing L/R test tones?
See what the effect is.
10
Lenny78
Posts 3
Lenny78 replied on Mon, Dec 27 2021 5:13 PM
I just tried playng those testtones. But its only when bass is punching the driver it makes those noises. I actually think its the driver too, but the speaker should lock down, when a driver is faulty.
Mr 10Percent
Posts 591
Lenny78:
My experience of the upper tweeter says it can play when damaged but the noise. Good if it is just the driver.
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Mon, Dec 27 2021 8:22 PM
Beolab 5 doesn't have any sensor to detect mechanical failure of the driver, so it will keep playing even when rubbers or spider web are damaged...
Lenny78
Posts 3
Lenny78 replied on Tue, Dec 28 2021 8:26 AM
But the speakers allways shuts down, to prevent the drivers, to get damagde.  I think there is a heat detector, but if this wasent caused by overheating that proberbly dont work, in this case.
Jack
Poland
Posts 30
Jack replied on Tue, Dec 28 2021 9:43 AM
First, I would swap the ICE1000 power amplifiers and listen to which loudspeaker there is interference, so we can confirm the efficiency of the amplifier or not. I had a few cases of damaged resistors on the ICE board and there was interference. Recently, I had two cases of damage to the silicone spacer and the insulator of the power transistor on the ICE1000 and continuous electric arc to the heat sink, in addition, an error appeared:
OS_ERROR (0x0753)
Fault in the Operating System.
A software problem has occured (hardware is OK).
Remove the AC power from BeoLab 5 for at least 5 seconds to reset the microcomputer.
0x0E41 (0x0E41)
0x0E55 (0x0E55)
Despite the BL5 error, it works.
Sorry for my English.
Page 1 of 1 (7 items) | RSS
DigiCert Secured Site Seal
