Helo, has anybody already successfully paired the Halo with the Beovision Horizon? I can check the checkbox in the B&O-App, but then I get an Error Message, that the Product could not be added :(
Thanks for your help
ChrisBerlin: Helo, has anybody already successfully paired the Halo with the Beovision Horizon? I can check the checkbox in the B&O-App, but then I get an Error Message, that the Product could not be added :( Thanks for your help
And one can control the Horizon
edit: in standby I also do get a message that the Horizon is not reachable/available on the network. Presumably solved with the Horizon settings.
Carolpa:yes And one can control the Horizon edit: in standby I also do get a message that the Horizon is not reachable/available on the network. Presumably solved with the Horizon settings.
Ok, now i have paired the Horizon successfully, but the Halo can’t wake it up. The Beo-app is capable of waking the tv up but not the halo. Any ideas?
ChrisBerlin:The Beo-app is capable of waking the tv up but not the halo. Any ideas?
Wake on WLAN is set to ON? (settings/wireless & networks/wired or wireless)
