How to choose hdmi1 from Beo6
HoffMaistro
Danmark
Posts 11
HoffMaistro Posted: Fri, Dec 31 2021 8:45 PM
Hello everyone 😊
Is it possible to choose Hdmi 1 on BeoVision 11 from Beo6. My BeoVision 11 er set up to beoremote one, so it dont react on all beo4 commands. (V.mem, DVD etc.) maybe i Can geate a spec. IR code in Beo6 setup tool, to activate hdmi 1?? Can Anyone teel me how the IR code must look like?
Best regards
Richo
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Jan 1 2022 10:33 AM
Hi Richo and welcome to Beoworld!
I don't have a BV11, but from experience you need to go into the TV's connections menu* and assign the hdmi 1 to one of the listed inputs.  You will then be able to select hdmi 1 by pressing one of the available source selections, such as DVD, V.MEM etc.
This should all be explained in the user manual.
* I think that the connections menu may actually be called the SOURCE LIST menu in the BV11.
Millemissen
Flensborg, Denmark
Posts 14,680
Hej Richo
The easiest way - if you want to use the Beo6 as your main controller - is to set the tv to be controlled by a Beo4/navi.
After that you can assign any source to (almost) whatever button/command you want e.g DVD for a connected Bluray player or DTV for an AppleTV box.
(Under Produktintegration….).
This should make it possible to access the sources with the Beo6.
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/TELEVISIONS/BEOVISION_11_WITH_BEO4/DA_Gettingstarted_BV11.pdf
If you have access to and can work with the confic tool for the Beo6, you should be able to tailor that to your needs.
HoffMaistro
Danmark
Posts 11
Hey Millemissen and Guy. Thank you wery much. Thank you for replying.
I know that i can chance the remote to be beo4 at the BV11 setup menu. My main contoller is beoremote one, which i like to use for the most. I mostly use my Beo6 to Control beosound 5,
i just Think that it would be Nice, occasionally, to Control my Apple TV (Hdmi 1) from Beo6.
But mayby it is not posible to do that if is stil want to have BV11 set up to use beoremote one as main controler.
I Just noticed that it is posible to generate a specific IR code in the beo6 setup tool program, and maby someone knew how af IR code that could activate Hdmi1 look like.
It could be fun to make it work.
Richo
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Jan 2 2022 10:39 AM
Richo Brems:
Yes you can generate specific IR codes in the Beo6 config tool.
However, to select hdmi 1 you need to send 'standard' IR codes to the Beovision 11, as already described.
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
