How do you connect a Beogram 4500 to an Beovision Eclipse ?
jandrego
Posts 10
jandrego Posted: Sun, Jan 2 2022 8:01 PM
The Eclipse is now used as the music system and I would like to add a Beogram to the system.
Or can I connect the Beogram directly to the Beolab 50s ?
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Jan 3 2022 11:28 AM
As long as the BG4500 still has its RIAA amp fitted, you could connect it to the TV's LINE IN socket as an 'Analogue Audio Source' as explained half way down this page: https://support.bang-olufsen.com/hc/en-us/articles/360042323152  I am pretty sure that Steve at Sounds Heavenly can supply a suitable adaptor when his site is back up after the Xmas break
But you wouldn't be able to control the beogram with the remote.
I can't answer the BL50 question, but am sure others will chip in.
jandrego
Posts 10
thanks Guy !!
Page 1 of 1 (3 items) | RSS
