No sound output of Beogram 1203
olofjens
Posts 1
olofjens Posted: Thu, Jan 6 2022 12:13 PM
Hi there,
I was given a lovely vintage B&O set for my birthday consisting of a Beogram 1203, a Beomaster 1200 and some B&O speakers. Now, the Beomaster works really well, but the Beogram had some (unexpected) problems when we tried it out. We had it serviced and now it runs all fine.
Except... when I first set up everything after servicing, only the left speaker had output. I then went to check where that problem lied. So to test this quickly I carefully stuck a paperclip end in the 5-DIN inputs of the Beomaster and both speakers reacted fine. So it must be somewhere between the tonearm and the 5-DIN output of the Beogram. I tested it again, and now there is no output at all, from neither speakers
I'm a little hesitant to break open a recently-serviced Beogram. Therefore, does anyone know the most likely cause of this defect?
All the best,
Olof
mr_anders_son
sweden
Posts 1,710
The needle is bad?
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jan 6 2022 1:40 PM
Leads broken off inside the DIN plug?
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
