Beolab 17 connection to non B&O sub - best way?
If I am connecting these from eg Essence via RJ45 Powerlink then I can daisychain one speaker to another. So presumably I can also daisychain to a sub (via RJ45 to RCA adaptor)?
I realise this does not deal with the bass reduction that you would get ( I think) by connection to a B&O sub but I have other ways of doing that
Or - other connection suggestions?
Hi
In the past I used BL3 along with Cambridge Minx X200.
Chromecast Audio > RCA input of Sub > BL3 via RCA output from Sub.
I reduced the bass load of the BL3 by setting position switch to 'Corner'.
So, I would do it as you propose yourselves.
Regards
Ravsted
Thanks!
My sub does not have RCA output so I need the feed from the Beolab... is that possible?
Yes
If you don't master soldering - contact Steve from SoundsHeavenly. He can get you the proper cable. Se sponsor link below.
Hi Ravsted,
This is all possible! Please feel free to get in touch via my sponsor link below with all the details of your setup and we can go through all the options to find which one best suits your needs.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
