Hi
Have problems with loading.
Opened player already and noticed in down part there is under the set of rollers
a part which don't move enough to release a small plastic hook to engage two rollers.
In a way it moves just to half way.
Anyone fixed this problem before?
Fixed
I think reason to all are those plastic parts which wear out and some of those get BIGGER by the time.
Used small file to few of those and everything works fine now. Added also silicone grease to some of those parts
which move against each other.
