Beoplay S8 no sounds
This post has 3 Replies | 0 Followers
Pro-Sa
Posts 4
Pro-Sa Posted: Sun, Jan 16 2022 3:35 PM
I'm new to the forum. I just got a Beoplay S8 from a friend for a good price.
The model I got is propably MK1 as it has 5 input satelites and the Mode option 'AMP'. No connection hub came with it.
I have connected the RJ45 cabel to RCA/Jack to my laptop to test it.
There were a really weak sound comming from both satellites but no sound from the subwoofer. After testing I can hear a really extremlly low sound from the subwoofer. If I try ti increase the volume from the laptop then the orange light on the subwoofer starts to shine and tuns off when i lower the computer volume.
My understanding is that the subwoofer works but there is an issue. I was lucky and found a connection hub a bit expensive but now a days it's hard to find one.
Can anyone give me a some tips here what I should to do ? thanks
leosgonewild
Helsinki, Finland
Posts 2,373
Is it set to LINE?
Pro-Sa
Posts 4
Pro-Sa replied on Sun, Jan 16 2022 8:31 PM
Yes, i have put it to LINE.
Pro-Sa
Posts 4
Pro-Sa replied on Wed, Jan 19 2022 6:49 PM
No I have bought a connection hub, the problem is still there. the sound is extremely weak only coming from the speakers but no sound from the subwoofer. help is appreciated
Page 1 of 1 (4 items) | RSS
