DIY Bang & Olufsen PC monitor based on parts from Beovision 6-26
This post has 3 Replies | 3 Followers
Ravsted
Denmark
Posts 345
Ravsted Posted: Mon, Jan 17 2022 1:50 PM
I had a BV6-26 I didn't use. Tried to sell it ... but there is really no market for those anymore. So I decided to use parts from it to create a PC monitor.
Saved the speakers and the IR receiver for later use. Removed the contrast screen and the aluminium frame.
Had to fix the area where IR receiver used to be.
Cleaned the contrast screen and put on a piece of black tape.
The result.
If anyone is interested... this is how the TV looks inside.
3D printed some brackets to support the aluminium frame.
Perfect fit. Glued in place.
Created a wood frame to fill the gap between contrast screen and aluminium frame. Oak... painted black.
The picture format of the early BV6-26 was 26" 15:9
The height is a perfect match with a 27" 16:9 monitor
In the control panel of the graphic card I can adjust overscan left/right to have a perfect match with the contrast screen.
Smile
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jan 17 2022 2:28 PM
Cool project!
Could you please provide a picture from the front, and maybe how it looks on a desk? Smile
Curly
FL, USA
Posts 366
Curly replied on Tue, Jan 18 2022 11:10 PM
More pics!!
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Ravsted
Denmark
Posts 345
Ravsted replied on Thu, Jan 20 2022 1:19 PM
A picture of the desk as requested.
I put the contrast screen on top of my iMac which will be replaced with a PC + monitor + contrast screen soon.
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
