Have successfully used a Mk1 Beocom 6000 since 2001 - Pyramid type base base station - Recently purchased another Mk1 handset plus table charger and am having difficulty registering it to the base station - Have reset handset - Display shows NOT REGISTERED and shows fully charged when press OK button - Removed existing handset from base station - Press centre button between the two pins - Red light flashes on base - Press handset button on new handset = REGISTER BASE - Press OK and display shows SEARCH BASE WAIT --- Revolving line at RH corner shows - Five minutes expires on base station and no registering confirmed - Any suggestions please ?
John: Any suggestions please ?
John t his should be in its own thread. Keith was just giving instructions on how to start a thread such as yours.
Edit
John did, see here => http://archivedforum2.beoworld.org/forums/t/497.aspx
BeoNut since '75
i have had the same problem any one got any ideas
