Display beolab Penta and beovision 7-40
This post has 4 Replies | 3 Followers
Andreas
Larvik Norway
Posts 21
Andreas Posted: Mon, Jan 24 2022 5:10 PM
I just got a pair of Penta 3, I connected then to my BV7-40 MkII and a BS 3000.
Three speakers are connected with 8-pins powerlink.
The display on the speakers do not show any information with this set up. Should it show anything?
When I'm connect the Penta directly to a BS2300 it shows the information.
Ravsted
Denmark
Posts 345
Ravsted replied on Mon, Jan 24 2022 9:19 PM
When you connect the Penta's to the BC2300 you use fully wired MK2 PowerLink cables and display is working.
Are you using the same fully wired MK2 cables when you connect the Penta's to the BS3000 ?
Regards
R.
MartinRK
Posts 80
MartinRK replied on Tue, Jan 25 2022 6:35 AM
Try checking underneath the speaker where you connect the PL cable. There should be a audio - video switch. As far as I remember this is for the display
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
If the Audio/Video switch is set correctly (Audio when connected to the Beosound, Video when connected to the TV) and the displays still don't work, then the Powerlink cables may not be fully wired.  All modern Powerlink cables have 8 pin plugs but not all of these will be connected inside the cable unless you have the fully wired mk.2 cables.  These cables are needed in order to light the speaker displays:-
https://soundsheavenly.com/powerlink-8-pin-din-connection/23-319-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Andreas
Larvik Norway
Posts 21
Andreas replied on Tue, Jan 25 2022 10:43 AM
Thanks to all reply, I will check the audio/video switch.
I guess that is the problem.
The cable seems to work both on the BC2300 and BS3000.
Page 1 of 1 (5 items) | RSS
