Essence Remote with BeoVision 7
This post has 1 Reply | 0 Followers
Tim84
Munich
Posts 98
Tim84 Posted: Wed, Jan 26 2022 1:59 PM
Hello,
I just got a Beosound Essence Remote from a friend, as his Essence stopped working. I now wonder if I could use the remote with my BeoVision 7 to turn on Radio and change the Volume. Does anyone know if this is possible?
thanks in advance
btw. is it normal that the volume dial is relatively hard to rotate?
Living room: BeoVision 7 MKV + BeoLab 7-2 + 2x BeoLab 8000 + BeoLab 2 + 2x BeoLab 4000
Office / guest room: BV 7-32 MKIV / BL7-1; BeoSound Core + Turntable
Kitchen: BeoPlay M3
Bathroom: Gira Radio + BeoLab Celestial
Entrance: BeoPlay M3
lawrencejmcook
Posts 742
Try setting the BS Essence remote to mode 7 (Beovision IR).
I’m not sure which source it will turn on: TV / DTV / other??
This link explains how to change modes: https://support.bang-olufsen.com/hc/en-us/articles/360045073252-How-do-I-set-up-Beosound-Essence-Remote-for-use-with-Beosound-Moment-
And this link shows you what the different modes do: https://archivedforum2.beoworld.org/forums/t/17876.aspx
Lawrence
Page 1 of 1 (2 items) | RSS
