Hi, I played a little bit with my Beosound 1 and BLGW and tried to play a normal Deezer Playlist with a "normal" macro. i Selected the Source Deezer, and then I used the "Playqueue add Deezer playlist" with the Number of an public Playlist, but nothing happened. But after i fired the macro, the BLGW doesn't work properly anymore, so that I have to restart the BLGW.
A Macro with selecting TuneIn works absolutely fine.
Any Ideas?
