Hello Beoworld.
I am an owner of a Beovision 7 MKII and a Beosound 5.
In June I am moving into an apartment and therefore I do not have as much space as right now.
I am thinking about selling my Beovision 7 and Beosound 5 and buying the new Beovision 11 and connecting it to an Apple TV.
Does anyone have some experience with the Apple TV and the new Beovision 11?
Is it easy to control the apple tv from the Beo6 or the Beo4?
MARKFS:Does anyone have some experience with the Apple TV and the new Beovision 11? Is it easy to control the apple tv from the Beo6 or the Beo4?
Yes, for sure. There's an Apple TV slot in the rear of the BV11. Your dealer can install, connect to a HDMI socket and link it up so it can be controlled using the Beo4. I rent most of my movies using the Apple TV.
You can also control the BV11 and Apple TV via your iPhone or iPad using the B&O remote app, if you prefer. I bought an iPad Mini to do this, but then found it was quicker and easier just to use the Beo4 to control everything, so stopped using the iPad remote!
Okay great!
Do you have any thoughts on the new netowork link / masterlink?
