Hi!
I have a deal $200 for Beosound 3000 + 2xBeolab 6000. But
Beosound glass doors are broken and one side of antenna is loose. I have a question
What the difference between 3000,3200, 4000?
Is it real to repair glass doors?
Thank you
Beolab 1, Beolab 8000, Beolab 6000, Beolab 4000
Beosound 9000, Beosound 3000
Beoplay H95
Beogram 8002
Hi
See product section of this site or visit beocentral for further details.
Beosound 4000 is the US version of Beosound Ouverture. CD + Cassette Player.
Beosound 3000 got CD.
Beosound 3200 got CD and HDD (hard drive)
What exactly is wrong with the glass door ? Is the wire mechanism affected ?
I have seen people getting a piece of glass fabricated and moved the bracket from the old glass door.
Regards
R.
Thank you for the fast reply! I will ask the seller about the mechanism. Is it possible to get exact sizes of the doors?
I can measure mine 😊
Got the BeoCenter 2300 but to my knowledge the Ouverture, BC2300, BC2500, BS3000, BS3200 all have identical doors.
Maybe someone else can confirm that ?
Thank you! I am confirming also the mechanism condition currently
I can't find the article with the home-made glass door(s).
It's not an easy-peasy job ... The glass has a dark tone, edges are rounded/smooth and the brackets must be moved (un-glued/glued) without damaging them.
Don't know how easy you can find them second hand where you live...
Hi guys
Thank you for your advices. Finally I bought it. The price was 200 for everything and only beolab 6000 usually goes higher.
Now I have Beosound 3000 without door but it works.
I would appreciate if somebody measures doors and hinges and their location and also makes a photo of glass somehow to understand tinting degree.
I will try to order custom made glass doors and hinges and if they will fit fine so I will be able to order for everyone who needed in the future.
Creating custom glass doors without having the bracket connecting to the wire mechanism is imho an ambitious project.
But at the end of day that is your decision.
Congrats with your purchase ☺️ .
Below you find som pictures of the glass.
156x335 mm
Further comments / pictures will follow as soon as the moderators releases my answer.
I've came across this add on a Belgian online marketplace.
Unfortunately for you it is a bit far away...
https://www.2dehands.be/v/audio-tv-en-foto/stereoketens/m1802212085-bang-olufsen
Beosound 5 Encore, Beolab 3, Beolab 11, Beosound Balance Non GVA, H9i
Thank you so much! Do you mind telling me the approximate thickness of glass? I do not want to make them too thick and heavy!
Thank you ! It is ok if price is reasonable, but I am trying to register there for 2 days already, and it fails. I mean the account registers but after that it asks to change a password and it sends link to the email which never comes and support did not answer :(
I have an address in Austria if he won't send it to USA
Try using a different email that hasn't got a spam filter?
I tried already three and social login. The email about registration and the mail with link to confirm email are passing fine. However the password reset email never comes. I checked spam. It was my first idea too.
Are you registered there?
After many trials my friend from Germany registered for me. Let's see
I saw also some doors on ebay from a German seller, costs 150€ per door.
Finally I bought doors with hinges for 100 euro from a guy from Netherlands. Thank you!
