Beogram 6000 platter goes up and down
This post has 1 Reply | 0 Followers
Neur03ngine
Netherlands
Posts 6
Neur03ngine Posted: Sat, Feb 5 2022 7:46 PM
Hi Beo experts and lovers,
I just had my Beogram 6000, which I inherited, serviced.
now almost everything works properly, except for the platter that seems unbalanced and is going up and down.
please check the video’s. It’s too much for the tonearm to handle so it can not play a record but jumps after every 360 degrees.
hope somebody has any idea on how to solve this.
https://youtu.be/sF5d1MNf3MI
https://youtu.be/2cy9xEiRtfs
regards, Mike
Spassmaker
North Germany
Posts 223
Spassmaker replied on Fri, Feb 11 2022 12:33 PM
Hi Mike
As you look close to the middle spindle you can see that it is working in different directions too, seems you should have a closer look for the platter pivot, maybe loose pivot or the plastic chim where the axle runs on inside is broken.
Kind regards
Christian
Page 1 of 1 (2 items) | RSS
