Greetings !!
It´s time to retire my Plasma because of burn in. I am still in awe of the funktionality and looks of the BV9, so i have aquired a Samsung UHD 50” as a replacement, and got it working on the Display2 DVI(Projektor) output of the BS3, after setting the appropiate resolution(1920x1080). However, when trying to connect to the Display 1 DVI, the Samsung wont accept the signal, says that resolution is unsupported. After having tried going into service mode (Menu Menu 00 go), I am not able to set the resolution manually.
Any pointers ??
(Am perfectly satified with the FullHD resolution of the BS3 (curtains😉) and the integration of my old ML system.)
Sincerely
Christian
Have already asked this in the Nordic section in Danish.
Solved. Needed to switch Autodetect off in the User service menu (Menu-menu, go to Options ,then Red Arrow-Go) Disable autodetection sets the output in safemode, and from there the solution can be set in Options in Main Menu.
Thank you for providing this feedback
