Beocenter 2500 Doors stopping suddenly
Oxotron
Posts 5
Oxotron Posted: Mon, Feb 7 2022 4:36 PM
i own a Beocenter 2500. I changed the belt and greased the doors slightly with silicone grease. But i have a problem with the doors, that doesn't seems very common.
The doors open smoth and but sometimes. when they should close, the stop after a few milimeters. Only sometimes and totaly random. Without a pattern. So i guess, it should be an electronic problem?
Pat
Posts 152
Pat replied on Mon, Feb 7 2022 9:56 PM
Don’t grease it, do adjustments on the top and bottom
Oxotron
Posts 5
Oxotron replied on Mon, Feb 7 2022 11:01 PM
Ah, the aligmet. Ok, thanks. I`ll try this.
Ipe
Posts 28
Ipe replied on Tue, Feb 8 2022 10:33 AM
Hi
at least mine is very sensitive to position of those parts which are fixed to doors. Have had two 2500 and in both of those I had to glue those holders back. If it's done already once before you should first try to take old glue carefully away as much as possible. After that's done and right positioning of those holders doors will probably move as they should.
Oxotron
Posts 5
Oxotron replied on Tue, Feb 8 2022 8:22 PM
Okidoki - it was the microswitch inside the mechanic. It was bent to much.
But thanks a lot for the help!
Page 1 of 1 (5 items) | RSS
