Searchable manual of MCL 2P
EN
Sweden
Posts 7
EN Posted: Tue, Feb 8 2022 9:58 PM
Hi everybody,
I have converted a manual of MCL 2P for being searchable. I used the software Abbyy FineReader 12 and it works excellent.
Here you can download it free for a limited time. https://www.dropbox.com/s/4q9adiex5iv4iyb/Bang-Olufsen-MCL-2-Owners-Manual.pdf?dl=0
The administrator of this forum cound have it on BeoWord.org for further download for lifetime. I'll have the file for download for a month.
I can convert more PDF manuals to be searchable if somebody need it. Just ask and put the file on this tread.
Sincerely,
Esa Nyberg
EN
Sweden
Posts 7
EN replied on Tue, Feb 8 2022 10:32 PM
Question,
I have a pair of BeoBox 3000 passive Loudspeakers, flat panel, type 6716 and a MCL 2P Amplifier.
I have a simple DVD-player with HDMI-connection.
I have also a couple of Din Plug Scew Connect, Male.
What do I need to play CD-music with this speakers?
Sincerely,
Esa Nyberg
Millemissen
Flensborg, Denmark
Posts 14,680
You’ll need a preamp in order to have volume control - the 2P is just an amp.
Best use a Beo-sound/center/master with Powerlink output and a fully wired PL cable.
Does the DVD player have R/L outputs - if yes, use a L/R to 5 pin Din cable.
You’ll also need speakers wire for the plugs from the 2P - the cable can be screwed onto the terminals of the 3000’s.
EN
Sweden
Posts 7
EN replied on Wed, Feb 9 2022 2:54 PM
Thanks a lot for your answer.
So BeoMaster have 5-Din connections...
I will research more.
Sincerely,
Esa Nyberg
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
