Hi , im working on a Beomaster 3300 which have a faulty michroprocessor, does anybody have a scrapped Beomaster 3300 with a working michroprosessor which i could buy ?. Partnumber 8340965 . best regards GERT PETERSEN , Horsens Denmark .
You could search (Google, etc.) for the IC 8049. Only order from a reputable source.
Or check with Beoparts.
It's a mask-programmed IC.You cannot use any 8049 CPU.
Yess, its mask programmed from factory , it needs to be the original one with the program for the Beomaster 3300 , i hope somebydy has got a scrapped radio with a processor i clould boy...
