Hi all,
I have severe symptoms of ”B&O sickness”. From the beginning of this year I have started to dream about the beautiful Beosound 9000, I am trying to find the MK3 -version in a good condition.
I already have a Beosound Core with speakers connected to my TV and stunning Beoremote Halo.
If I’ll find a BS9000 that I would like to buy:
1. What else do I need? (NL / ML Converter?)
2. Does any of you have a BS9000 working with the HALO remote? (How does it work and what can you do with the Halo? Play/Pause/Skip…?)
3. Wires? (What wires do I need and how should I wire it? I am planning to use it with active speakers connected to the Core and wirelessly in my system.)
Thanks for your help in advance
EetuXx: Hi all, I have severe symptoms of ”B&O sickness”. From the beginning of this year I have started to dream about the beautiful Beosound 9000, I am trying to find the MK3 -version in a good condition. I already have a Beosound Core with speakers connected to my TV and stunning Beoremote Halo. If I’ll find a BS9000 that I would like to buy: 1. What else do I need? (NL / ML Converter?) 2. Does any of you have a BS9000 working with the HALO remote? (How does it work and what can you do with the Halo? Play/Pause/Skip…?) 3. Wires? (What wires do I need and how should I wire it? I am planning to use it with active speakers connected to the Core and wirelessly in my system.) Thanks for your help in advance
I believe you’ll also need a BeoLiving Intelligence to use the Halo with NL/ML devices, however you can control the BS9000 via the NL/ML converter through the B&O app and Beoremote One via the core.
