Beolab 8000 MK1 signal sense fail
sgeneste
Posts 1
sgeneste Posted: Tue, Feb 22 2022 6:34 PM
Had a cut/broken powerlink cable from my BEOLAB 8000 speakers to the BEOSOUND 9000. Rewired the broken section some time later, reconnected all (at LABside + SOUNDside) and system/sound worked fine.
Reorganized cables, plugged and unplugged powerlink at SOUNDside, and next the left speaker did not switch on anymore. Moved the right DINplug and replaced the left with it, changed the corresponding BEOLAB-switch from left-to-right, but speaker remains off (red light). QUESTION: could the left speaker be in some kind of a "fault-state", is there a reset procedure? OR might there be an electronic component broken? Thanks for your response!
Page 1 of 1 (1 items) | RSS
