Playmaker and Masterlink - again
This post has 12 Replies | 2 Followers
Stefan
Switzerland
Posts 26
Stefan Posted: Tue, Mar 5 2013 9:35 PM
Dear all
I have a BS 9000 that works perfectly fine, plus a Mac Mini feeding digital music into the system via BeoPort.
I acquired the Playmaker a) for curiosity and b) to enable my girls to stream iPhone-Music to the system without complication. Playmaker feeds into BS 9000 via A.AUX. It is just so much easier than uploading their music to the Mac Mini first (and actually I am quite glad some of their music remains on their devices and does not get to the central system Smile)
As my BeoLink Actives are quite old, they do not support selection of A.AUX from link rooms. Therefore I thought that purchasing a Converter NL/ML would allow me to add Playmaker as a master source to the masterlink - which then could be called from all rooms.
I did read in other threads that selecting Playmaker in that setup would require the CD button. However, I would like the CD button to activate the BS 9000' CD-Changer.
Any idea if and how this might work?
Thank you very much! Stefan
Graham
Liverpool
Posts 16
Graham replied on Tue, Mar 5 2013 10:48 PM
could just upgrade the software in the active's
mjmedlo
Posts 922
mjmedlo replied on Wed, Mar 6 2013 2:04 AM
zuegers07:
Dear all
I acquired the Playmaker a) for curiosity and b) to enable my girls to stream iPhone-Music to the system without complication. Playmaker feeds into BS 9000 via A.AUX. It is just so much easier than uploading their music to the Mac Mini first (and actually I am quite glad some of their music remains on their devices and does not get to the central system )
Can't you just press volume up in those active rooms and trigger a.aux?
Stan
Chicago-area USA
Posts 869
Stan replied on Wed, Mar 6 2013 2:48 AM
Try a.tape
Stan
Chicago-area USA
Posts 869
Try a.tape
Stefan
Switzerland
Posts 26
Stefan replied on Wed, Mar 6 2013 11:43 PM
Correct. But dealer charges EUR 65 per upgrade...
Stefan
Switzerland
Posts 26
Stefan replied on Wed, Mar 6 2013 11:44 PM
Thank you Stan.
A.TAPE to do what? To access A.AUX sources from link rooms? Or to access BeoPlayer behind NL/ML gateway?
Cheers Stefan
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Mar 7 2013 3:31 AM
Sorry, typing from my phone so I cannot be verbose. A.tape from the beo4 should enable the aux input from a link room. Stan
Stefan
Switzerland
Posts 26
Stefan replied on Thu, Mar 7 2013 11:24 PM
zuegers07:
Thank you Stan, works just fine!
Stefan
Switzerland
Posts 26
Stefan replied on Thu, Mar 7 2013 11:25 PM
bnoblueboy:
... and pay around EUR 1'000 ....
.... or simply use A.TAPE instead; it even has a button on Beo4
Stefan
Switzerland
Posts 26
Stefan replied on Fri, Mar 8 2013 6:23 AM
mjmedlo:
Didn't try that; once I knew that A.TAPE does the job I was happy with it.
Stan
Chicago-area USA
Posts 869
Stan replied on Fri, Mar 8 2013 9:16 PM
mjmedlo:
I believe volume up will turns on whatever source was last used... or if you're pressing volume up on the Beo4, whatever it was last set to.
mjmedlo
Posts 922
mjmedlo replied on Fri, Mar 8 2013 10:46 PM
Stan:
I'm using a PM through BS4.
To trigger A.AUX I simply turn on the BS4/PM and then volume up in the bl 3500 room and voila.
Page 1 of 1 (13 items) | RSS
