sorry i have just picked up a wonderful beosound 1 in full working order from a charity shop presume previous owner has upgraded can anyone tell me where i can get the leads required to add a deck to it the deck has two leads out.
thanking you
Nic
If your deck has a preamp built in then you need a lead to connect from RCA to the aux, if you look at the sponsors of this site you will see Sounds Heavenly, Steve will be able to help you with this.
If your deck does not have a pre-amp then you can get one from him as well.
Toby
