Just something to share, should it be useful to someone!
My CDX lid would sometimes be stuck open or closed, or even halfway.
After much fiddling (new belt, adjusting, you know) it turned out to be bad solder joints at the green and light grey connectors on the motor command PCB, invisible without a magnifying glass...
I should have known, but so many posts explained how a bad belt or lid adjustments could have such an effect led me on the wrong tracks (for once)!
Jacques
chartz:led me on the wrong tracks (for once)!
Its always the little things, well spotted.
Are you back on track :-)
