Beosound encore 5 and NAS Drive
This post has 21 Replies | 1 Follower
Paul cheacker
Spain
Posts 130
Paul cheacker Posted: Mon, Mar 11 2013 9:20 PM
Thanks to all that helped me with my router issue all set now to look into buying a NAS drive to connect to my apple airport extreme.
So thought I would ask you for advice on the best NAS drives to look for?
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
BeoHut
Posts 482
BeoHut replied on Mon, Mar 11 2013 9:34 PM
Have a look at Synology. Recommended by dealers. Fast and accurate with good software. For a back-up you could use a Raid-system. The 12-series will do the job.
mbee
Paris, France
Posts 1,842
mbee replied on Mon, Mar 11 2013 9:37 PM
I had a LaCie 2big, there was a problem : the DLNA index was corrupted after each wake up, so I never had a complete library accessible without re-indexing...
Went the Synology way with a DS412+, and now everything is just perfect.
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Mar 11 2013 9:39 PM
I also have a Synology (DS212, I think) and it's fantastic and accessible from just about any device. Currently using it to store ripped (legal) Blu-ray movies, my audio tracks and other media. It has 2 x 2TB drives, which were about £160 for both.
Paul cheacker
Spain
Posts 130
Where did you buy your DS212?
Paul cheacker
Spain
Posts 130
Paul cheacker
Spain
Posts 130
Paul cheacker
Spain
Posts 130
Mbee, thanks for your reply. Glad you answered as I was considering a lacie 2big as I have been using their drives for several years but had no NAS from them. Your response has helped me decide to steer clear of them for this purpose. Thnks
Lars
Munich
Posts 146
Lars replied on Tue, Mar 12 2013 1:17 PM
Amazon was my friend. I own a DS411 and it works fine and streams movies as well as music without any issues.
BS9000, BC6, BC2, BL3, BL11, BL3500, BL2000, BeoTime, Beo EarSet2 3i, Beo, BEO DropStop, BEO Bottle Opener, BeoCom5 including Table Stand, ATV
Christmas Prize Draw 1st Winner 2010 - THANKS A LOT!!!
Struer Trip 2012 - THANKS A LOT!!!
Paul cheacker
Spain
Posts 130
Ok just brought a synology from amazon will be here in some days. In order not to loose time I have one more question. My computer is an Imac, I also use an iPad. So all my music is stored on an external hard drive through iTunes. Now I understand I will need to migrate my music to the NAS drive when it arrives, however is there anything I nees to thnk about now. For instance will I still be able to use iTunes, as my music store. Etc etc?
moxxey
South West, UK
Posts 5,359
moxxey replied on Tue, Mar 12 2013 3:47 PM
applemac1:
Just re-direct your iTunes library so it points to the music on the NAS drive, rather than from your computer. When iTunes starts, it will load the library from the NAS.
See http://support.apple.com/kb/ht1449
Copy the music folder from your computer to the NAS (your NAS mounts as a drive on your Mac), then relocate the source of the library.
Millemissen
Flensborg, Denmark
Posts 14,680
http://www.synology.com/support/tutorials_show.php?lang=us&q_id=521
Greetings Millemissen
Paul cheacker
Spain
Posts 130
Yep thought so, and I take it that by doing this, the music will also show up on the encore aswell.
Millemissen
Flensborg, Denmark
Posts 14,680
Note! Beosound5Encore does not support ALAC.
Paul cheacker
Spain
Posts 130
Hi all ok need the last bit of the puzzle help. I now have a synology 212J Nas it is set up and I have itunes stored with some music, format of music is mp3. What I now need help in is getting the beosound 5 encore to see the nas. have no idea how to do this.
Millemissen
Flensborg, Denmark
Posts 14,680
Page 22 of the userguide:
"Add a NAS as a music library ...
> Use the pointer to highlight MODE.
> Turn the wheel to select SETTINGS, and press twice then GO on your music system.
> Use the pointer to highlight SERVICE
SETTINGS.
> Turn the
wheel to select MUSIC STORAGE and press GO.
> Select the name of your NAS in the menu.
Press GO to select."
And of cource The DLNA-server must be set to on in the settings of the Synology.
The files must be stored in the right place on the NAS according to the userguide.
You don't have iTunes on your NAS. There might be a iTunes-server (DAAP-server) running on the NAS as well, but you don't need that for the Encore - just the DLNA-server.
Does this makes sense to you - otherweise feel fe to ask again.
Paul cheacker
Spain
Posts 130
Press what twice?
Paul cheacker
Spain
Posts 130
Ah yes now I see, however when doing this it doesnt show the synology nas drive
Paul cheacker
Spain
Posts 130
Its done thanks ive solved it at long last.
Millemissen
Flensborg, Denmark
Posts 14,680
Enjoy Smile
Paul cheacker
Spain
Posts 130
Thanks to everyone for the wonderful help. Anyone know how I make these thread closed as answered
Millemissen
Flensborg, Denmark
Posts 14,680
You just did it!
Page 1 of 1 (22 items) | RSS
