Beosystem 2500 FM Radio (& tape) problem
This post has 5 Replies | 3 Followers
max666
Posts 4
max666 Posted: Tue, Mar 12 2013 10:37 AM
The device is 1992 Beosystem 2500.
I have noticed that the FM Tuner is much quieter then CD at the same volume settings - when the CD volume is set to 30 it is about as loud as FM Radio at 50. Is this normal?
Also - and I yet have to confirm this once more - it seems that the tuner sometimes doesnt work immediately when the beocenter is turned on, it once took few minutes for tuner to start playing. This made me suspicios that some of the capacitors are bad - is this common on this devices?
And I have common problem - tape deck doesnt work. I will disassemble the beocenter to check for the common problems found on this forum - fuses and belt. Anything else to check?
auric
Posts 90
auric replied on Wed, Mar 13 2013 12:24 AM
Do you have a proper FM antenna plugged it?
It can make a difference.
max666
Posts 4
max666 replied on Wed, Mar 13 2013 7:28 AM
I use normal dipol antenna, does 2500 require some special impedance?
Btw, as long as I am disassembling the unit, I am going to order all new drive belts - doors, tape and cd tray. (Tape deck doesnt work at all, and sliding doors sometimes stops halfway - I noticed that motor is spinning over belt which is quite loose).
I have found all 3 belts on ebay for cca 30EUR - is this OK or is there a better or better quality source?
And could you point me to some guides/steps for belt replacements and sliders cleaning? I have already opened up the unit and now am searching around forum how to carry on.
auric
Posts 90
auric replied on Sat, Mar 16 2013 12:28 AM
I don't think it needs a special antenna, but most of the times it needs one else the tuner is quite weak.
Where are you located? If in the US just order from B&O authorized service center.
The belts unfortunately take a lot of time to change! Lots of dis-assembly required. Make sure you get high quality belts to ensure you don't have to do this again soon!
Can you get the tape mechanism to engage?
Are you certain ALL fuses are OK? There are I think 3 or 4 of them in the unit. If one goes the unit will still "half work."
max666
Posts 4
max666 replied on Tue, Mar 26 2013 9:00 AM
I bought complete set of new belts (doors, CD tray and cassette deck) and have done a big service yesterday (took me almost 6hrs).
Beosystem now works like a charm :)
But its a hell of a job and interesting thing happened in a cassette deck:
The belt was not just wrapped around motor but it had also melted in a blob of melted rubber which took more then an hour to clean:
JasGrewal1964
Posts 2
Where did you buy your belts?
Page 1 of 1 (6 items) | RSS
