Good morning,
Whe I switch on our Beovision Avant, the loudness is at 60. I want to have 24 or 26, so nobody wakes up in the evening from turning the tv on.
How can I realize that?
Thank You very much!
Jan
You can do very easily.
When watching TV:
Press menu on your BEO4 (if you have an STB installed, press menu again) and the Setup menu will apear on the screen
Select Sound and an horizonal set of options will appear. Move to VOL an adjust the vilume to your needs.
Then press GO to confirm your new settings
The next time you sitch on your BeoVision it will startup wil this sound level.
hfat
Tank You very much, it worked :)
