Beomaster 2400 - buttons don't respond
This post has 8 Replies | 0 Followers
loeffens
Posts 13
loeffens Posted: Tue, Mar 12 2013 7:57 PM
I am currently repairing a beomaster 2400. Beautiful unit I must say! However, it was nit working when I got it. In the meantime I got it to work, i.e. switch on. The problem I am facing now is that the 'buttons' don't respond when I touch them. It stays on FM4, also volume can't be changed (fairly loud now, haha).
I opened up the unit to find copper things sticking out under the 'buttons', I tried to bend them a bit so they would hopefully touch their contact point. This doesn't work, problem persists.
Is anyone of you known with this problem? And more importantly; does anyone know how to fix this?
All hour help is greatly appreciated!!
hamacbleu
Québec, Canada
Posts 194
hamacbleu replied on Tue, Mar 12 2013 10:19 PM
When I repaired mine, I couldn't get the volume down... I reopened it and touched the small pin related to that control with a finger. It was working, so it was definitely a bad contact with the copper thing... If the programs are not changing when you touch these pins with bare hand, then the problem is elsewhere... Are the caps original? I.e. red plastic one? if yes It might be a good idea to change them all in case the fault persist...
loeffens
Posts 13
loeffens replied on Wed, Mar 13 2013 2:32 PM
Thanks for your answer! What pins do you mean? I reopened my beomaster and can't seem to findthe pins you mean. I can't really figure out where these copper things connect?
hamacbleu
Québec, Canada
Posts 194
hamacbleu replied on Wed, Mar 13 2013 2:57 PM
When you remove the panel with the copper tabs, look carefully on the electronic board at the place where the tabs would go if it would be in it's place. You will see small metal pins, about 1 centimeter in lenght that goes up from the electronic board. There's one pin for each function. The copper tab HAS to sit on them for the sensi-touch to function properly. Try to touch these pins (only those pins...) with a finger: You body act as an antenna and send a signal to activate the related functions. If it works, then it's just that the copper tabs don't touch these pins properly when close... It's tricky to put the front panel properly, but when you will locate these pins, it will be much easier for you...
loeffens
Posts 13
loeffens replied on Thu, Mar 14 2013 10:21 AM
Thanks again! Indeed it is tricky to put the front panel back, I can't fit it in properly. Dothe copper things have to tocuh the pins with the back (straight) of the tip in the front (v-shaped)?
Sorry to go in such detail, but I can't get it to work at the moment. Thanks in advance!
loeffens
Posts 13
loeffens replied on Thu, Mar 14 2013 12:15 PM
Update! I managed to get the copper things connected to the pins, they were bent in the wrong direction.
However, then the next problem shows up. When I assemble the unit the volume controles work fine. But on the right side it stays at "fm5". All the copper things are perfectly aligned, so they must tocuh the pins as well. When I push another button ("tape" for example) it switches to that channel but immediately switches back to fm5, as if that one is always triggered. Thorough cleaning and some sanding doesn't help. When dissassembled, it switches perfectly between channels when I touch the pins on the board.
Any suggestions? Thanks!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Mar 14 2013 12:27 PM
This can happen if the indicator lamps are of incorrect wattage.
It can also happen if a transistor for the sensitouch field is shorted but wrong lamps are far more common.
Grab a lamp kit and replace the lot.
BTW: The kit comes with detailed (dis-)assembly instructions with photos and english text.
The bronze forks should NOT be bent in any way, the front panel will have to be fitted the right way and, yes, it's tricky.
loeffens
Posts 13
loeffens replied on Thu, Mar 14 2013 3:10 PM
Thans Martin. But if the problem world be in the lamps or the transistors, wouldn't it be weird that everything is working perfectly when the sensi-touch is not connected, i.e. when I touch the pins on the board? That is what made me think there was sommering else wrong?
Dillen
Posts 13,191
Dillen replied on Thu, Mar 14 2013 4:41 PM
Yes, but your fingers used directly on the pins will give a completely different (and much stronger) signal.
But check those bronze forks again. They will have to grip their respective pin with their forks and with a little
tension too.
Page 1 of 1 (9 items) | RSS
