Beovision 3 32": Installation of surround module and RF modulator
Schierup
Posts 4
Schierup Posted: Thu, Mar 14 2013 1:32 PM
My Beovision 3 32" unfortunately broke down yesterday. It seems to be the picture tube. However, I have a spare one, but it doesn't have the surround module and RF modulator as the broken Beovision. Does any of you know, if I can just install the modules from the broken Beovision to the spare one? Does it need reprogramming or anything?
Thank you in advance!!
Best regards
Jakob
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Mar 14 2013 3:18 PM
I would guess that no reprogramming is required but I am not at all sure!  Why not swap the modules and see what happens?
Others may object, but couldn't you also move the main TV EEPROM (6IC6) across to the 'new' set?
(And before you try all this - are you sure the tube is faulty? Symptoms?)
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Mar 15 2013 7:55 PM
Installing the modules can without any problems.
The soundmodule is the easiest one, the RF takes a bit more work. Mind the tiny RF cable.
Schierup
Posts 4
Schierup replied on Mon, Mar 18 2013 7:55 AM
Hi
Thanks for your answer. I'll try to swap the module and see if smoke is comming out. :o)
BR Schierup
Schierup
Posts 4
Schierup replied on Tue, Mar 19 2013 6:07 AM
Hi
I swapped the 2 modules and everything seems to be working perfectly! Thanks for your comments!
Schierup
Robert
Holland
Posts 204
Robert replied on Tue, Mar 19 2013 10:24 PM
Hi Jakob,
Here a link to a specialist in Germany for a tube. Just in case once you need one.
http://www.ebay.de/itm/Rohre-fur-Bang-Olufsen-Avant-32RF-Beovision-3-32-24-Mon-Garantie-TOP-/200907185174?pt=DE_TV_Martin&hash=item2ec7005c16#ht_2805wt_922
Regards, Robert
SirOne
Posts 3
SirOne replied on Mon, Mar 25 2013 8:51 AM
Hej Jakob - I have same situation. Exactly. Is it difficukt to move the surround module from one beovision 3 to another ? I have no drawing, instruction or manual.
I thin k the modul is called dolby R digital module type 4003 (PCB32), Ive seen a picture of a package in E-bay, but can anyone have instructions ?
Søren (SirOne) - im dansih, so if possible i can also understand danish instructions
Schierup
Posts 4
Schierup replied on Tue, Mar 26 2013 3:08 PM
Hi Søren,
I'm also danish, but I haven't got any instructions in either english or danish. The replacement was indead very easy. I moved the Surround module and RF module. You only have to remove the backplate of the television (4 screws) and then unscrew the module. The surround module has 1 cable attached and the RF module 2 cables. Both with very easy access. The IR module was sitting on the back site of the motherboard (?) and was difficlt to access. The RF module I only removed from the brokes television.
Best regards
Jakob
Page 1 of 1 (8 items) | RSS
