hi hopping some one can help me ..i have a beogram 4004 with a burnt bulb for the foto resistor.want to replace it but not sure of the watts and volts ..i think 20 volts. thanks
Do you mean the Photo-resistor for the sliding Ruler?
If so, it is an infra-red LED, and you can't see any visible light.
You can do a normal diode check with a multimeter, to determine if it is OK.
Unless someone has fiddled with the circuit, and destroyed it, these usually last a lifetime.
Did you try to test it by putting 20V across the terminals - then you've destroyed it for sure.
If you are referring to the lamp at the base of the tonarm, then that can be replaced by a white LED, with 1K 1Watt dropping resistor.
Menahem
