Terminal 3000 and 5000 remotes
This post has 4 Replies | 0 Followers
ouverture
London
Posts 263
ouverture Posted: Fri, Mar 15 2013 11:45 PM
does anyone know if the 3000 can be used on a Beosystem 5000 ?
only need it for volume control and muting -  so I am thinking it is the same era ( 85 to 87) , but thought I would check first in case for some reason it may not work.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Mar 16 2013 6:49 AM
It can't.
The Beosystem 5000 uses unique codes and will only work with Terminal 5000 and Master Control Panel 5000.
ouverture
London
Posts 263
ouverture replied on Sat, Mar 16 2013 7:44 PM
maybe the 3500 would be better, the button layout on the 3500 looks the same as the 5000
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Mar 16 2013 8:38 PM
The 3500 uses Beolink 1000 codes which are different again. The 3300 uses these codes in a basic form as well. Neither work the 5000 I am afraid.
Peter
ouverture
London
Posts 263
ouverture replied on Sat, Mar 16 2013 8:48 PM
thanks Peter & Dillen, oh well my search continues for a Terminal 5000 to use instead of the MCP
Page 1 of 1 (5 items) | RSS
