Today, after a lot of years of pleasant viewing my AV 9000 TV stopped working. The problem can't be too big I guess. When I press TV on my beolink 4 the little stand by light changes to green, but one second later it turns red again and nothing happens....
All help is welcome.
Wouter
Something inside the monitor top part neeeds to be looked after by a qualified repair man.
I got my AV9000 IMP DOA and it got serviced. A day or to later the red light as I recall did the same and it went back to service. It came back again and still works great to this day.
I had the same problem with the second AV9000 I bought. It's a known problem, and I'm pretty sure replacing C101 in the power supply will cure the problem - No guarantee, but I would suggest you to start with that one.
But, this is not a job for anyone! The TV contains high voltage parts, so if you don't have any electrical skills, then I would suggest, that you leave it to someone else! There's no reason to risk getting injured or damaging the TV, by trying to repair it yourself.
- Dennis
