Beolab 4500 display question
Zwets
Posts 111
Zwets Posted: Sat, Mar 23 2013 1:17 PM
Does anyone know that if I connect a set of Beolab 4500's as rear speakers to my Beovision 8-40 I will get display info? The BV 8-40 is also connected to my Beomaster 4500 through a ML/MCL convertor but all speakers are connected directly to the TV.
Thanks for your help!
hemenex
Posts 569
hemenex replied on Sat, Mar 23 2013 4:06 PM
I do have an ouverture connected to my BV8-40 through masterlink with Pentas on the TV and can tell you - no Display Sad
Pentas directly on the ouverture did display source etc.
Switching A/V for the displays doesn't change anything - the BV8 obviously doesn't send data through Powerlink...
I do miss the display, too
    hx
Zwets
Posts 111
Zwets replied on Sat, Mar 23 2013 4:33 PM
The config guide program does indeed mention that no display data is sent to Penta but it does not mention the 4500
Zwets
Posts 111
hemenex
Posts 569
hemenex replied on Sat, Mar 23 2013 4:49 PM
Zwets:
The Power Link wires used for the displays are the same - whatever B&O- speaker you connect. They are pins 6&7 on the DIN Plug.
  hx
Millemissen
Flensborg, Denmark
Posts 14,680
NO display!
Zwets
Posts 111
Zwets replied on Mon, Mar 25 2013 4:04 PM
Thats a shame. thanks
Page 1 of 1 (7 items) | RSS
