I have just bought a Beomaster 3000-2 tuner/amp and on purchase i did not notice a crackle and hum on the right channel only. It increases at higher volume. I would love to try on solve it and fix it myself. Can anyone help or suggest where i should start?
Many thanks
Welcome to Beoworld !
Replace the electrolytic capacitors.The board mounted cylindrical ones in particular.
Thanks very much for your reply!!
I will give it a go and let you know how i get on.
Mike
